by Rookie » Wed Mar 10, 2010 6:23 pm
hey,
The s14 and 15 DE's have variable valve timing, but its only on the intake cam and it only changes the timing, not the lift, and duration as the VE does. As for a CA, sure in turbo format its ok, but it would get punished hard in N/A by the SR20VE. If the DE is complete, with EVERYTHING, then its a good buy, but otherwise keep looking, as it will cost heaps to track down little parts you may need.
Dave
Locost 7: Powered by 1587cc of turbocharged FURY! coming to a town near you soon.
"If you can leave black marks from the exit of a corner, to the braking point of the next, then you have enough HORSEPOWER."- Mark Donohue
