Ok time for another update, due to a bit of good luck instead of a week 4wd course (because of the bad weather) I ended up in Chch and working on my car, which makes a change!
Anyway, the plan was to have it painted soon, but got a few quotes etc, and have now decided paint can wait, I will be sporting the popular un polished alloy and white gel coat fibreglass for now! This means I will have money to put towards getting the car finished and on the road sometime in the next 6months (fingers crossed)
First of the pictures is the great work my dad has done on my Stainless Fuel tank and inbuilt surge tank. Filled with water to test for leaks (only one which has been fixed) total of 34L in the tank, and 2L in the surge tank with pump fitted.
Here is the lift pump for the surge tank
Next was a lot of fitting and testing the side and rear panels ready to be installed, and also making up the 3/4 panels. Big news is I actually stuck down a few of the internal panels with glue and rivets! (in the boot area and under the scuttle)
Recieved a set of guards thanks to Mcgregor Motorsport, here are some pics of one in place with the wheel, and can also just spot the new rear brake disc (drums have been removed now)
Next things to do are
Finish setting up rear brakes (caliper bracket and handbrake cable)
Send the car to Mcgregors for some front end adjustment and new front wishbones
Line side panels with vinyl (in cockpit area) and cut some holes for the exhaust etc
Bonnet is getting z3 vents fitted
