Fuel guage and sender wiring
Anything else
ibreadmore
Post by ibreadmore » Thu Sep 11, 2014 9:13 am
I have:
Smiths BF2232/00 fuel gauge
Smiths FT3331/56 level sender
Tried wiring them up last night and hit a snag.
Gauge reads perfect on full but reduce the level sender to empty and the gauge doesn't move past half full. Are the two items compatible?
Anyone got any advice?
If you see the tree you are driving into, you have understeered. If you only hear it, you have oversteered....
1985 Chevron Classic - 1256cc Chevette engine
Sales Executive at Rotorua Hyundai - Come see me for your new car - (07) 348 2494
ibreadmore
Re: Fuel guage and sender wiring
Post by ibreadmore » Thu Sep 11, 2014 9:51 am
May have answered my own query. :roll:
Just remembered that i got a new tank, the old one is under my deck and may contain a different sender unit that matches the gauge.
ibreadmore
Post by ibreadmore » Thu Sep 11, 2014 11:36 am
might need to calibrate
http://www.mgb-stuff.org.uk/fuel.htm
ibreadmore
Post by ibreadmore » Thu Sep 11, 2014 8:28 pm
Got the other sender from the old tank. This one is a FT5301/11.
Only has a single spade terminal connection. Must earth through the tank.
No matter what I tried I can't get it to work correctly. Reads full when empty and vice versa.
Any suggestions.
Sent from my iPhone using Tapatalk
Rookie
Post by Rookie » Thu Sep 11, 2014 10:54 pm
You best bet is to buy a POT for 50 cents from jaycar and find out what resistances you guage needs to work, and then finding a sender that works.
Locost 7: Powered by 1660cc of British FURY! coming to a town near you soon.
Remember: If a mechanic can do it, so can YOU!
ibreadmore
Post by ibreadmore » Fri Sep 12, 2014 8:51 am
POT?
Rookie
Post by Rookie » Fri Sep 12, 2014 11:30 am
Potentiometer.
Post by bzrse7en » Fri Sep 12, 2014 1:45 pm
There are two types of smiths guages, bi-metalic and magnetic (has two coils inside guage.
The senders are different and are incompatable. Bi-metalic has been around since the 70s.
Both type guages are calibrate-able.
Have you got a voltage regulator on the guage? This drops volts down to 10v, without it, you might see the symptoms you describe. My build diary has a little bit on smiths guages.
jp928
Post by jp928 » Mon May 04, 2015 12:52 pm
Bimetallic ? All senders I have ever seen (apart from late capacitance types) are wiped resistance units. Bimetallic is used to sense temperature changes, not fluid levels in my experience.
jp Almac
Post by bzrse7en » Mon May 04, 2015 5:12 pm
The gauge is bimetalic, not the sender. I have one here, pulled apart.
