Use this forum to openly discuss anything you would like regarding the project cars in the build diary's
* Edit post
* Delete post
* Report this post
* Information
* Reply with quote
Forum Rules. EVERYONE MUST READ BEFORE VIEWING OR POSTING
Postby KiwiBirkin » Tue Nov 10, 2009 6:10 pm
Poject Discussion Forum Rules
This is a new section of where you guys can discuss other users cars. There are just a few rules that need to be followed for this forum to stay nice, clean and easy to use:
1. ONE thread per car. Search the forum for an existing thread before starting your own, things stay tidy that way.
2. Try and stay on topic if you can.
3. Thread titles must be in this format: Username's and the car project
I have created this section so it keeps the build diarys clean and allows the builder of the car to keep us updated a bit like a BLOG so please use this section to disscuss the builders cars and we should see a much easier forum to navigate.
Post by Wanganui7 » Wed Jul 11, 2018 7:53 pm
Anyone wanting to ask questions on this build welcome to do so.
heavyseven
Post by heavyseven » Wed Jul 11, 2018 11:28 pm
Questions? I don't know, looks like you have it under control :)
Good job so far!
Post by Wanganui7 » Sat Jul 14, 2018 10:34 pm
Thanks, going ok seen I've never built a car before. Built lots of boats, but no cars. Learning heaps though.
Post by Wanganui7 » Sun Oct 21, 2018 5:11 pm
Can anyone supply a simple diagram for a na 1.6 miata circuit opening relay . Am using an aftermarket 5 terminal relay . Need to know which wires go to which terminal numbers ( 30, 85, 86, 87, 87a) ???
Post by Wanganui7 » Sun Oct 21, 2018 5:24 pm
This relay opperates the fuel pump. From what I gather with the ignition key on run , the air flow meter switch turns on with the air coming into engine ( light green wire keeps relay and pump on) With ignition key on start air flow meter is off ( not open yet ) and the fuel pump is turned on by the violet wire coming from the sign fuse.
Post by Wanganui7 » Tue Oct 30, 2018 6:00 pm
Found the problem, wrong type of relay
Grippa
Post by Grippa » Tue Oct 30, 2018 8:47 pm
I can’t comment about the MX5 but do know old Toyota’s use a twin coil relay for safety on the fuel pump so it turns it off the fuel if the engine is stalled. Is this the same ?
Post by nz_climber » Thu Nov 15, 2018 9:05 pm
Glad you found the problem with relay and got that sorted. No good about the crimp, but soldering them is just adding another failure point where the solid meets flexible. What sort of crimp tool do you have? I have wired 4 cars and never had a crimp come loose (Using rachet crimp tools and correct gauge crimp for the wire)
